4l60e 94 gmc sierra - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2008, 01:56 AM
4l60e 94 gmc sierra
Got a tranny that works fine in drive or overdrive but if i manuall shift to 1st or 2nd it slips like crazy. But if in drive it cycles thru the gears fine. Any suggestions would be appreciated
Old 01-15-2008, 05:43 PM
Crosley's Avatar
Wiki Edits: 1659
that is interesting.
Mileage on the transmission? Any recent repair work or fluid service?
when in manual 1 gear , there is actually another clutch pack applied. The low roller clutch would still be holding
Old 01-15-2008, 08:14 PM
mileage not sure
the truck is new to me last yr has 170000 miles on the truck. I did get a transmission service done to it but the tranny was doing it before. I was just kinda hoping it would help. It is weird it will light the tires if in drive or overdrive but just revs up and moves slowly if i drop it down to 1 or 2
Thanks
'96 4L60e into '94 van HRC Transmission - Rearend 1 09-06-2008 02:29 PM
94 gmc sierra spydi Transmission - Rearend 3 12-05-2007 05:14 PM
4l60, Or 4l60e 1994 Gmc 4wd buddy powell Transmission - Rearend 4 10-14-2004 06:16 AM
just bought a 94 gmc sierra shane7643701 Engine 8 03-01-2004 12:23 AM
question on how to remove factory stereo from 94 gmc sierra shane7643701 Interior 0 02-28-2004 07:15 AM
