4L60E Accumulator Sequence - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2009, 07:09 PM
I have seemed to mess up the seqence in which i install the 1-2 accumuator and the 3-4 accumulator. I have the small single seal on one side and a double seal on the other side i can post pics if it would help.
Thankyou
Larry
Old 09-17-2009, 08:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thankyou
Larry
i am not sure what you are doing. the OEM pistons for the accumalators are the same for 1-2 and the 3-4
Old 09-17-2009, 11:46 PM
thankyou but i figured it out one is a aftermarket sonnax so it threw me off
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
700r4 to 4L60E swap chevy_c10 Transmission - Rearend 19 05-10-2009 08:30 AM
98 astro 4l60e what swaps out? 3rdgenLT1 Transmission - Rearend 4 06-06-2007 09:16 AM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
