4l60E Before and After Pics
2 Attachment(s)
98 K1500 350 .30 mild cam
Well it took me over a month get this thing back together. Installed the Monster Trans SS kit. Should be pretty nice I would think. I will update when its back in the truck. Thanks to everyone that helped me along the way! This is a list of what went in this thing. Rear Heavy Duty 5 Pinion Planetary ▪ Front Heavy Duty 5 Pinion Planetary ▪ Chrome Transmission Pan with drain plug ▪ Paper Gaskets ▪ O-Rings ▪ Lip Seals ▪ (3) Molded Pistons ▪ Sealing Rings ▪ 4L60E Corvette 2nd Gear Servo ▪ 4L60E Super Servo 4th Gear Cover ▪ High Performance Steel Kit ▪ High Performance Clutch Kit ▪ 4L60E Filter ▪ 4L60E Wide High Performance Band ▪ Teflon Pump Bushing ▪ Delco Front Seal Retainer Clip ▪ 4L60E Superior Shift Reprogramming Kit ▪ Hardened Pump Rings ▪ 4L60E 13 Vane Rotor Gear ▪ 4L60E 13 Vane Rotor Guide ▪ 4L60E 13 Vane High Rev Kit ▪ Heavy Duty "Beast" Sun Shell ▪ Heavy Duty 29 Element Sprag ▪ Heavy Duty Wide Rear Sprag ▪ 1-2 Shift Solenoid ▪ 2-3 Shift Solenoid ▪ Manifold Switch ▪ EPC Motor ▪ 3-2 Solenoid ▪ PWM Solenoid ▪ TCC Solenoid with Harness |
If that is one of those push button transfer cases, you should split it and put in a case saver pump piece while you have it out.
I have the "shifter style" 4x4 selector on the floorboard.
I'm not very familiar with the transfer case. Do you recommend that I do anything else while it is out? |
If it has the shifter on the floor I believe you are good. Just make sure it has fluid in it.
Did you check the Pump/Rotor/Slide clearances?
| All times are GMT -6. The time now is 03:47 PM. |
