Hotrodders Bulletin Board
#2
re: 4l60e boost valve difference????
Sonnax is a alloy type material, uses O-rings for more sealing around the boost valve. TransGo is a steel / ferrous material , no O-rings. Depending on how late model 4L60E you have the early design valves will not fit with out machine work. In bone stock OE applications, I have received complaints of too firm of shifts with a larger boost valve in the pump. The "E" RWD trannys respond quickly to shift mods
======== Be kind to your children... some day they may be decide what nursing home to put you in |
#4
nope. the dual land inner valve in each unit , each land is a different size usually. One land is main boost , other is reverse boost
#6
never seen a difference. pressure is pressure. Some folks like the Sonnax for a similar design material of the OE boost valve
Back to top |
Similar Threads for: "4l60e boost valve difference????"
| Modifying Holley baseplate so power valve references manifold on s/c motor | blownS10blazer | Engine | 5 | 09-05-2008 10:21 PM |
| Is this (bigger) valve sitting right afte the new seats and valve job? | sizemoremk | Engine | 16 | 12-11-2005 12:18 AM |
| AFR or Vortec heads? Cam? | rodent | Engine | 10 | 10-26-2005 01:15 PM |
| Broken valve spring??? | Miligav383 | Engine | 6 | 05-16-2004 09:40 PM |
| Stock eliminator | 78 monte | Engine | 5 | 01-02-2003 05:10 AM |
