4L60E Carnage - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2010, 09:47 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
4L60E Carnage
Anybody have an idea what can cause this on a fresh rebuild?
It came out of a 4x4.
Low roller was installed the right direction and all the planets spin freely.
Name:	IMG_0554 (Small).jpg
Old 01-30-2010, 10:18 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Most common failure cause in the low roller clutch is neutral drops or similar shock loads from a 4x4 jumps - gets some air and hits the ground with engine power still applied
Old 01-30-2010, 10:42 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Interesting. Could a bad transfer case cause such a shock?
Old 02-02-2010, 12:46 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Doubt it. That looks like the product of a neutral slam. Or a 'something' slam.
T-400 to 4L60E swap - yoke & drive shaft? y5e06 Transmission - Rearend 6 11-03-2009 07:47 PM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 10:12 AM
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 02:51 PM
4l60e Trans. GMCTRUCKS Transmission - Rearend 11 10-21-2007 02:39 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 08:47 PM
