4l60e case ball check location - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 03:44 AM
I have a 2004 Avalanche with standard issue 4l60e trans, I have a schematic of the ball check location for the valve body side, Also the case side, My problem is it seems like there is an upgrade or change up for the case side, I only have the earlier schematic with 2 balls, one caged at bottom center and the other just above the accumulator, I am thinking there is now a 3rd at the top left, earlier pics show a square hole at the top left with a blank bottom but my trans has a tunnel(hole)instead of blank base that I believe the third ball came out of, Is anyone familiar with this.
thanx
Old 04-19-2012, 01:46 AM
SSedan64's Avatar
May find Info in one of these:
http://www.google.com/search?tbm=isc...eck%20location
Old 04-20-2012, 12:00 AM
Thanks SS,,I just went right to the source and asked a tech buddy (Calgary Transmission),,Turns out there definitely is 3 ball checks in the case, The one at the top left goes into a 1 inch deep tunnel at the base of that particular gallery, I thought so but had to be 100% sure, The pics I looked at did not show it, Was most likely a very early 90s 4l60e in the pics
Can a 1999 4l60e case be used for 2002 with bad case lugs misterchevy Transmission - Rearend 3 02-26-2012 07:20 AM
4R100 check ball question bbuss Transmission - Rearend 0 04-21-2011 04:45 PM
700r4 check ball location question ruined344 Transmission - Rearend 6 03-10-2011 06:32 AM
Input shaft check ball 8843astro Transmission - Rearend 3 03-19-2007 04:29 PM
4L60E check ball location? gemini86 Transmission - Rearend 11 04-18-2006 10:02 PM
