4l60e case defect question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2013, 09:03 AM
Was curious what you guys thought about this hole in the case. Would it stop you from rebuilding it?
Old 03-22-2013, 09:17 AM
I'm sure you could get that welded back. But if you have a couple extra bucks, I'd buy another rebuilder of CRAIGS LIST and rebuild it. I've never been fond of repairing things with extrra holes. Also, when i look at the picture blown up, it looks like the case is real thin there, or is it my eyes at my age
Old 03-22-2013, 09:38 AM
Yeah the aluminum is real thin there. Can you believe a yard sold this me as tested, working? I was going to bite the bullet and rebuild it but this is getting ridiculous.
Old 03-22-2013, 01:43 PM
Yea, you even have to be careful when you buy on Craigs list. You should be able to take it back to the yard and have them give you another one. I bet they'll say you did that when you took it apart. That is why i use one extra one for parts. In my case, I used three to build two. Don't know why, i had so much fun rebuilding one 200-4r, that i got carried away and built a second one to the extrem. Good luck.
Old 03-22-2013, 09:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is the way the case is machined. Do not weld those holes up.
the round hole should have a cup plug with very small hole in it.... that sprays oil on the band
The jagged edge hole should have a check ball capsul installed in it on the servo side..
Old 03-22-2013, 11:57 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
I second Crosley. They look funny but are definitely supposed to be there.
4L60E transmission case damage abbazabba Transmission - Rearend 3 07-25-2012 01:52 PM
4l60e case ball check location vanislejames Transmission - Rearend 2 04-20-2012 12:00 AM
Can a 1999 4l60e case be used for 2002 with bad case lugs misterchevy Transmission - Rearend 3 02-26-2012 07:20 AM
Name that paint app defect! Russianblue Body - Exterior 8 08-24-2007 05:35 PM
windsor defect? goose Engine 3 02-03-2004 12:42 PM
