4L60E check ball capsule leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 04:33 PM
I tested the check ball capsule by pouring parts solvent through the passage. I did have a steady stream of solvent leak thru to the inside of the case. I am under the impression that there should be no leakage at all if the capsule is working.
Called one trans shop to see what it would cost to get replaced. He says to just replace the case because it is too hard to remove and install.
Other shop says could replace but he has only replaced one in 30years. Said it should be fine even with small leak.
Any opinions??
Old 07-25-2012, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
They do tend to leak.. It takes a little bit of work to replace the capsule.
I've replaced the capsule several times. Machined up tools to pull the capsule and to drive the new capsule in with damage is the real trick.
The Following User Says Thank You to Crosley For This Useful Post:
abbazabba (07-26-2012)
Old 07-26-2012, 10:10 AM
Sonnax P/N 77701-076
Sonnax has a fix that I use on all 4l60e's I build P/N 77701-076. It eliminates the need for removal of the check ball capsole and installs under the separator plate in the cavity by tapping it into place.
The Following User Says Thank You to c65shoebox For This Useful Post:
Old 07-26-2012, 11:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info on the p/n 77701-076: http://www.sonnax.com/system/instruc...701-076-IN.pdf including info on what to use to pull the old one.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 10-16-2015, 09:55 PM
Here's a video on youtube from transmissionbench.com. It shows you how to remove and install the check ball capsule from the case. It's not that hard to do. If it is leaking to the inside of the case, replace it. Regardless of how much it leaks. It will only leak more with time. Remember, doing a bench test of this capsule there is no fluid pressure. When the transmission is operating, the fluid is under pressure. Which it will leak even more and you'll have a pressure loss on the 3/4 clutch pack.
https://www.youtube.com/watch?v=wj1AVEgDvPE
Old 10-17-2015, 01:36 PM
We replace every one, every time, in every case with a solid plug.
You can get the old ball capsule out with a regular 3/8" bolt. Just run the bolt into the capsule, drive it in with a hammer, turn it with a wrench to lock the threads into the tail end of the capsule. Then using a slide hammer, pull it out. Auto Zone sells 3/8" cup plugs that you can then install in place. They will never leak again after that. There are no detrimental side effects from making this modification.
4l60e, capsule, checkball, chevy, transmission
4l60e case ball check location vanislejames Transmission - Rearend 2 04-20-2012 12:00 AM
4R100 check ball question bbuss Transmission - Rearend 0 04-21-2011 04:45 PM
Input shaft check ball 8843astro Transmission - Rearend 3 03-19-2007 04:29 PM
4L60E check ball location? gemini86 Transmission - Rearend 11 04-18-2006 10:02 PM
57 Hydra-matic check ball MeligN Transmission - Rearend 3 04-15-2004 07:29 AM
