-   -   4L60E and a chevy 283 engine question (http://www.hotrodders.com/forum/4l60e-chevy-283-engine-question-231974.html)
hotrod fozzie 04-18-2013 05:18 PM
can you use a 4L60E ( BOLT UP AND WORK) WITH A 283 ??, Not sure if all small blocks are Essentially the same.Wanting to run a 283 in my s10.
techinspector1 04-18-2013 08:20 PM
Yeah, I'm pretty sure it'll bolt up, but the problem is with the "E" part of the transmission (Electronic). Read through this write-up and get educated.....
What's Needed to Install a 700-R4 or 4L60E Trans Behind Carbureted 350? - Hot Rod Magazine
vinniekq2 04-18-2013 09:10 PM
I hope the 283 is well warmed over? I would like to have a 12 second 283 powered street car
