4L60E and a chevy 283 engine question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2013, 05:18 PM
hotrod fozzie's Avatar
REAL HOTRODS have FLAMES!
can you use a 4L60E ( BOLT UP AND WORK) WITH A 283 ??, Not sure if all small blocks are Essentially the same.Wanting to run a 283 in my s10.
Old 04-18-2013, 08:20 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, I'm pretty sure it'll bolt up, but the problem is with the "E" part of the transmission (Electronic). Read through this write-up and get educated.....
What's Needed to Install a 700-R4 or 4L60E Trans Behind Carbureted 350? - Hot Rod Magazine
Old 04-18-2013, 09:10 PM
vinniekq2's Avatar
I hope the 283 is well warmed over? I would like to have a 12 second 283 powered street car
chevy 283 engine swed Hotrodding Basics 1 07-01-2012 06:36 PM
283 Chevy engine id questions Bayville SS Engine 7 04-11-2007 08:29 PM
Chevy 4l60E trans. Question whynot Transmission - Rearend 3 04-18-2006 09:36 PM
Chevy 5.3 V8 Small Block Engine 4l60e Trans Woody31coupe Engine 8 12-15-2005 04:37 AM
Chevy 283 engine gcusick Engine 3 06-29-2002 07:28 PM
