4l60e in a chevy tahoe 1997, problems with upshifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 08:21 PM
I have a 4l60e in a chevy tahoe 1997, no check engine light, will not shift from 3rd to fourth or overdrive. it seems to be in get home mode. any ideas?
Old 07-06-2012, 08:38 PM
Crosley's Avatar
Wiki Edits: 1659
Welcome to Hotrodders.com
I edited the thread title. We dont use ''help'' as a thread title here.
Use of a proper thread title helps the members and the search function on the board
Old 07-06-2012, 10:16 PM
oh ok thanks for the heads up...
Old 07-07-2012, 08:47 AM
Crosley's Avatar
Wiki Edits: 1659
What is the mileage on the trans (If you know) , or is this a recent rebuild?
Please clarify.. Does the trans 'not shift to 3rd' or does the engine rev up when 3rd gear should be there? The 1-2 shift is OK? Then 3rd gear is nothing, like a neutral?
BTW; 4th gear is over drive. Perhaps you are calling converter clutch lockup as over-drive?
Old 07-07-2012, 09:25 AM
well there is approx 40,000 on a rebuild. third gear is like a neutral. 1 and 2 work as supposed to.
Old 07-10-2012, 06:53 PM
Crosley's Avatar
Wiki Edits: 1659
Sounds like the 3-4 clutch pack is burned up.
97 Tahoe 4L60E transmission Fischerfolks- Transmission - Rearend 2 06-17-2011 09:22 PM
4L60E Manual Upshifts Only Hot 123pugsy Transmission - Rearend 4 06-01-2011 03:44 AM
1997 4l60e problems.. cheezehead69 Transmission - Rearend 6 03-27-2009 06:10 PM
1997 tahoe rehab parton2000 Introduce Yourself 1 06-26-2006 11:31 AM
