4L60E Converter Selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2012, 04:24 PM
Hello all,
I have a 5.7 350 vortec .30 over daily driver+occasional tow(less than 5 times a year)
with comp cams 08-300-8 (grind cs 262h-r12)
duration at .050 206(intake) and 210(exhaust)
I rebuilt the trans and just beefed it up a little.
I estimate I will be pushing between 325 hp and 350 hp.
I called summit racing tech department to get a converter and guy says to just use the old one. I thought they always needed to be replaced with a trans rebuild as well as engine mods?
Any suggestions on this? There were no issues with the trans before rebuild.. just did it with the engine build all at one time.
Old 10-31-2012, 01:51 AM
SSedan64's Avatar
With that Cam a Stock to mild stall increase would be fine. I wouldn't go too high with Towing in mind.
You should have the TC flushed/cleaned before reuse. If it was a low mile unit reuse, if not replace it, they're cheap. The TCC/TorqueConverterClutch may be worn.
The Following User Says Thank You to SSedan64 For This Useful Post:
abbazabba (10-31-2012)
Old 10-31-2012, 08:45 AM
It had 272,000 on it so I think I will just replace it. I certainly don't want to remove the trans just for the tc.
Thank you for confirming my thoughts.
Old 11-01-2012, 08:04 PM
for sure replace it
i have used the highest stock stall converter on motors around 500hp and no problems
they usually run 200$ new
454 C10 Tq converter selection ekacpuc Transmission - Rearend 2 06-05-2011 12:47 AM
Carb and Converter Selection Jackson72ss Engine 0 03-30-2010 11:01 AM
Tourque Converter Selection wild_man84 Transmission - Rearend 4 01-26-2009 05:57 AM
Torque converter selection raidmagic Transmission - Rearend 3 02-22-2005 09:08 AM
Torque converter selection 1meancuda Transmission - Rearend 3 10-23-2002 08:00 PM
