Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-29-2004, 09:56 AM
bluesman123's Avatar
bluesman123 bluesman123 is offline
4L60E Cooling Question
I hope I didn'e miss the answer to this in the knowledge base, but I did look.
I have a 1991 Sonoma that I put a 1998 5.7L Vortec and 4L60E tranny in. With me and 20 gallons of gas it weighs 3260 pounds. I do not tow anything...just a daily driver.
The engine/tranny came from a C1500 truck and was equipped with both an oil cooler for the engine and a tranny cooler. I removed the engine oil cooler and that worked fine. My question is can I also remove the tranny cooler?
Can I just plug the 2 ports on the side of the tranny that the cooling lines connect to? Will this cause the tranny to overpressure or get damaged in any way?
Is the 4L60E designed to require a cooler? Will I damage it by not running a cooler? Should I use any particular transmission fluid (I use Redline in the engine and the differential)?
Thanks for all your help!!
Dave
Old 02-29-2004, 11:59 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
re: 4L60E Cooling Question
the number 1 cause of automatic transmission failure is heat. always run a tranny cooler. with a 4L60E don`t rely on the cooler in the radiator either, run a aftermarket external cooler.
Old 02-29-2004, 12:05 PM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
Cool re: 4L60E Cooling Question
Yes, the 4L60E must have a cooler hooked up.
Do not plug the cooler line holes
Save the earth , choke a tree .... save a squirrel
Old 02-29-2004, 12:07 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Overqualified Underacheiver.
 M&M CUSTOM's barnstar
Re: 4L60E Cooling Question
The engine/tranny came from a C1500 truck and was equipped with both an oil cooler for the engine and a tranny cooler. I removed the engine oil cooler and that worked fine. My question is can I also remove the tranny cooler?[color=red]NO[/color]
Can I just plug the 2 ports on the side of the tranny that the cooling lines connect to? [color=red] NO [/color]Will this cause the tranny to overpressure or get damaged in any way?[color=red] YES [/color]
Is the 4L60E designed to require a cooler?[color=red] YES [/color] Will I damage it by not running a cooler?[color=red] YES [/color] Should I use any particular transmission fluid (I use Redline in the engine and the differential)? [color=red]Whatever GM recommended for fluid for that transmission.[/color]
Dave
[color=red]Engines aren't inherantly designed to make use of an oil cooler, but one is added in certain cases (snow plow prep package, diesel, heavy duty, towing). A transmission is designed without provisions to self cool as necessary, and almost all transmissions have provisions for external cooling lines to send the fluid to something elsewhere that will assist in the cooling process.
The most common place to have the transmission fluid sent to is the outlet tank of the radiator. The most efficient method is to send the fluid to an external cooler mounted in front of the radiator.
Heat is the number one problem an automatic transmission can have, followed by abuse.
[/color]
Old 03-01-2004, 10:11 AM
Thanks very much for your help, DoubleVision, Crosley and M&M!!!
I really appreciate it.
Dave
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
