4l60e does not shift now - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2009, 08:27 PM
Put a carb set up on a 350 and it had a TBI system and know to will not shift is there a cheap fix to this.
Old 04-29-2009, 08:53 PM
Crosley's Avatar
Wiki Edits: 1659
you need a stand alone controller to shift automatically the 4L60e and control internal pressures... about $850.00 on up in price.
Old 04-30-2009, 01:23 PM
No, either go back to TBI, or put in a stand alone computer which will need all the TBI sensors you took off to be functionally mounted somewhere, or replace the transmission with a 700R4, however, the 700R4 will require an analog to digital converter to drive the speedo. The speedo looks like an old fashion analog unit, but looks can be deceiving, its digitally driven.
Bogie
Old 05-02-2009, 12:05 AM
Only cheap solution is to put the TBI back on.
4l60e delayed shift into 3rd when it's cold outside stevo71 Transmission - Rearend 3 12-20-2008 06:03 PM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
4l60e wont shift from first without backing off gas chevy71z Transmission - Rearend 8 08-10-2008 09:57 AM
4l60e shift point question silm man Transmission - Rearend 2 02-19-2006 03:23 AM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 08:02 AM
