4L60E DTC81 and DTC82 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 12:35 AM
Hi crosley,
I hooked up the scanner and got these codes. Any idea how it come about. I took the car out one day and burned two spark plug wires because it was too close to the header on this motor so i went out and bought new wire and installed them. I did drove home without knowing that the wires burned and the car barely move. After that the tranny wouldn't shift out of 1st. I was working fine before the 2 spark plug wires burned out. I had no idea what happened. Tranny want to shift out of first for a second then it stalled and rpm shot up. Please help!!!!!!!!
Thanks
Old 02-06-2006, 06:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
those are codes for 1-2 & 2-3 shift problems.
I am not understanding if you melted only spark plug wires?
Originally Posted by LT1Powered-RX7
Hi crosley,
Thanks
