4l60e erratic 1-2 shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2009, 11:10 PM
1998 k1500 260000km and the 1-2 shift is smooth then rough and smooth again. Temp dosent seem to matter but does shift slightly better cold. The fluid is clean smells good. nothing in the pan for friction material. The accumulator piston and spring where changed with no help.
Is this trans just wore out? Everything else works great. Never pulled anything with it. Any help is greatly appreciated.
P.S. Ive done searches and found nothing.
Old 02-07-2009, 07:27 AM
Crosley's Avatar
Wiki Edits: 1659
pull the pan off check the accumilator assembly.
i have seen worn out accumilator pistons or broken springs , cause whacky shifts.
You may have a separator plate worn out with a sticky check ball. That requires the valve body removal .
Old 02-07-2009, 11:48 PM
Ive already replace spring and piston so Ill replace the plate. Is there an aftermarket one?
4L60E Hard shift mystery driving me crazy ericanderson Transmission - Rearend 6 10-03-2008 08:33 PM
4l60e First Gear Wont Shift chevy71z Introduce Yourself 5 08-11-2008 10:58 AM
4l60e wont shift from first without backing off gas chevy71z Transmission - Rearend 8 08-10-2008 09:57 AM
4l60e shift point question silm man Transmission - Rearend 2 02-19-2006 03:23 AM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 08:02 AM
