4l60e feels like park brakes on,no rev. only 2nd gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 11:33 AM
Hey guys, i have a 4x4 1998 chevy s10 blazer with a 4.3 and 4l60e transmission that i need your help with. In park it idles fine but i can feel a load on the engine and with it at wot it onlys revs to about 3000rpms (like its in gear with the park brake on).In reverse it has this same "load" feeling and feels as though it wants to move forward but wont. In nuetral it barely moves forward and rolls back wen u let off. In the "OD" "D" or 2nd position it slowly creeps forward as u give it more gas feels like its taking off in 2nd or 3rd (I beleive its second from speed and rpm comparison) and wont rev past 3000rpms. In the 1st position it does nothing has a load feeling wont rev high just sits. I can drive it around the block and dont feel any shifts and takes off slow.The trans was ran low on fluid which "killed" it. I believe it has same symtoms with it pluged in or not and has no ses light on. Also this trans has the removable bell housing and the fluid looks pretty good but i believe thats because it was ran really low then refilled. I have rebuilt one th350 with great results and am planning to attempt a rebuild with this 4l60e with a TCI master racing overhaul kit. Im hoping it has wore clutches or a vb issue. I have worked on one of these trans before only to install a shift kit with the trans in the vehical on a previous truck i had so a have minor experiance with them. Just want some oppinions on these wierd symtoms with such a complex trans. Thanks for all the help in advance i know you guys are always a great help!
Old 08-29-2010, 10:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like the trans needs to come apart for proper rebuild if it was run low on fluid.
The symptoms you describe seem all over the place and I really can not offer a simple answer.
Old 08-29-2010, 09:58 PM
thanks crosley thats what ill do. Sorry i didnt know how to make it any more simple the symtoms are very wierd nothing ive ever seen before ill just tear it down and hope all the main components are still intact.
Old 09-01-2010, 06:57 PM
Well i took the trans apart today and found that the 3-4 clutchs where "glued"to the steels this must be the reason it felt that it was in gear at all times. I also managed to break my tcc because i didnt realize it had to be removed before the pump could be removed.lol but oh well, anyone else who attempts this rebuild make sure to remove this first.at the moment im waiting for my tci kit. I also was wondering how important the low reverse clutch support retainer is? At first i thought it was a piece of unidentified metal that wasnt suppost to be there. i may have slightly bent it and dont want to reinstall it. any input would be very appreciated. will post pics soon.
Is kickdown gear same as 2nd on C6 cboy Transmission - Rearend 1 08-02-2005 09:40 PM
4L60E Stays in first gear!!!!! Cletis234 Transmission - Rearend 10 05-22-2005 08:19 PM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
