4l60e First Gear Wont Shift - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 05-14-2008, 11:30 AM
Hello all
I have a problem with a 94 chevy z71, the tranny wont shift out of first gear until you back off the gas. Then everything good, unless you tromped the gas then it might down shift all the way to first.
the valve body been replaced. 1-2 spring accumalor all good. 2-4 servo been check , all solnoids check out. No codes, the scanner says the tranny is getting the infor to shift but doesnt.
Also you cant manual shift the tranny either.
But after backing off the gas the tranny works fine until you stop again.
fuild was okay normal after 25000 miles.
Just couldnt of any thing beside valve body that could cause this problem with out some other problem , slipping etc. thanks for any help.
Old 05-14-2008, 11:47 AM
You should have posted this to the Transmission / Rear End section... I'm not sure how many people will see it here in the Introductions.
Old 08-09-2008, 05:03 PM
I'm having a fairly similar problem. Mine won't shift from first but not all the same as yours. What I've gotten so far is the governor gear could be stripped or something else messed up on the governor itself. Also the throttle valve could be plugged. I was told a quick way to clear it is to start the engine with PARK engaged and take the TV cable off the carbeurator/EFI, and pull it back and forth real quick. If that doesn't clear it but you knwo it's the problem, throttle valve will have to be taken apart. I don't really know anything, just relaing info given to me. Please respond if you get yours fixed.
Old 08-09-2008, 08:03 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Best to ask over in the Transmission/Rearend forum......this forum is for Introductions.
Old 08-10-2008, 11:01 AM
problem solved
my problem was a worned 2-4 band, replace the band and drum plus the 3.4 pack because they was burned some. tranny working great
Old 08-11-2008, 11:58 AM
lets cut it up's Avatar
Welcome
4L60E won't start in 1st gear... Augusto Transmission - Rearend 1 06-01-2006 03:09 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 08:48 PM
Gear Shift Knobs dagman54 Interior 2 11-02-2004 09:08 AM
GM column gear shift knob 54 Chevy Interior 1 09-08-2003 09:03 AM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 06:52 PM
