4l60e fit small block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 08:17 PM
will 86n305 fit 93 700r4???
I got a chevy 1986 305 5.0 small block will it fit a 93 700r4 out of a camaro??? anyone know im assuming it should, please let me know. Thanks Sean
Old 10-20-2011, 08:43 PM
Will a 4l60e 700r4 out of a 93 camaro fit a 1986 chevy 305 small block?
Old 10-20-2011, 09:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, the trans bolts up.
I would check that 1993 trans from the Camaro. It should be a non "E" as in a 4L60 trans with a TV cable on it.
Is the Camaro a V6 engine?
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
small block to big block swap in a 91 camaro help! Greg O Sandsten Engine 6 11-02-2010 11:02 AM
Chevy 5.3 V8 Small Block Engine 4l60e Trans Woody31coupe Engine 8 12-15-2005 04:37 AM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 11:45 AM
