4L60e Floor to column shifter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2012, 12:19 PM
I know this is reverse of what the human race is doing, but I have a LS1/4L60e out of a 2002 Camero (Floor shift) and I want to put it in a car and keep it's stock column shifter. I want it to be a sleeper...
It there a kit for that?
Buy another 4L60e from a truck?
Give up and get a floor shifter like everybody else?
THANKS!!!
Old 01-24-2012, 02:00 PM
Last journal entry: Some More Roll Cage Fabrication
Lokar has some cable shift adapters for steering columns. I used one in my nova and had great success.
Old 01-24-2012, 02:09 PM
THANKS!!!
The transmission neither knows nor cares whether the shift arm is moved by a floor shifter or a column shifter. The trucks actually use a cable on the column shifters anyway. Either adapt one of these or use the aftermarket kit as suggested above.
By the way, there's no "E" in CamAro...
column to floor shifter jd71cam Transmission - Rearend 9 10-12-2008 03:28 PM
Adapt column shifter to 700R4 or floor shift? 40FLIER Transmission - Rearend 1 06-20-2008 12:11 PM
column to floor shifter camino_man General Rodding Tech 5 07-27-2007 08:24 AM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 06:56 PM
switch reverse ilghts from column to floor shifter MuscleBlock81 Electrical 3 09-16-2002 12:34 PM
