4L60E Input Drum Differences--B-29 & B-85 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2011, 11:45 AM
Okay, as some of you know I've been building quite a few Chevy transmissions lately.
A while back I posted about how an input drum can be bad on the 4L60E and yet there was no way to test them before you put them in... Since then I have been air-checking each and every drum with a puddle of trans fluid around the spot where the shaft is pressed into the aluminum drum checking for air leaks around this press fit.
What I have witnessed is that both drum styles have an orifice hole right there close to where the bearing sits. This orifice hole bleeds fluid off from the 3/4 piston when it is pressurized. This makes the 3/4 arrangement a feed/bleed set up.
Now the differences between the two styles of drums is that the B-85 style drum bleeds off a LOT more fluid/pressure (larger diameter orifice hole) than the B-29 style.
I'm wondering if anyone can account for why they did this? Are they trying to move more fluid through the 3/4 pack to aid in cooling? Additional lubrication to the input drum bearing? Did they alter the programming in the computer to raise line pressure in 3rd/4th to account for the greater pressure drop due to the larger bleed hole?
As an aside, I've found out that B-85 style converters seem to be far more likely to come apart than the older B-29 styles did. Are these 2 things correlated?
I know these are technical questions but I was hoping someone with more experience than I could shed a little light on the subject.
I've been toying with the idea of reducing the orifice hole on the B-85 drums down to the same size as that found in the B-29 drums. Anybody ever tried this? I know GM opened that hole up for a reason, but given that the B-85 drums and converters are far more likely to fail than B-29's I was wondering if there was any merit to altering them. Since the 3/4 clutches are the weakest link in these transmissions, I'd think reducing the orifice hole may raise line pressure to the clutches and help them live longer. Another benefit.
removing the clutch hub of the reverse input drum old yukon Transmission - Rearend 4 02-01-2011 09:37 PM
4l60E 4X4 2WD DIFFERENCES 123pugsy Transmission - Rearend 4 01-06-2010 10:37 AM
how to air check reverse input drum? t00lmanii Transmission - Rearend 4 10-25-2009 06:36 PM
input drum air check rocmemphis Transmission - Rearend 11 05-11-2006 08:30 PM
700r4 Input Shaft/Drum Interchangable to 4l65E Shaft/Drum?? syclone477 Transmission - Rearend 3 01-01-2004 04:06 PM
