Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 02-23-2007, 06:06 AM
Ohio-Dan Ohio-Dan is offline
4L60E interchange
Will a 2000" 4L60E interchange with a 94' 4L60E?
Both are out of an S-10, and both came off of a 2.2 motor.
I know the 2000' model has a two piece case, but I'm wanting to know about splines, mounts, and electronics. Thanks, Dan
Old 02-23-2007, 05:10 PM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: 4L60E interchange
electronics are different. Lockup controls of the converter clutch are different. I would suggest the correct trans for the vehicle
2000 unit would be a 3 piece case ( removable bell housing)... converter is different , location of splines
Be kind to your children... some day they may be decide what nursing home to put you in
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4L60E interchange"
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 01:51 PM
Hollander Interchange? Longboard Hotrodding Basics 3 04-03-2006 08:15 AM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
4L60E interchange question Jessie Transmission - Rearend 5 01-05-2005 05:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
