4l60E issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 06:06 PM
Last journal entry: PICTURE TEST
4l60E issues
I finally got the trans in my truck that i rebuilt.
I have no d or OD. If i put the selector in drive/OD it just freewheels. if i put it in 2 or 1 the truck will move. Reverse seams ok. Where do i start looking for the problem??
The trans did something like this orginally, before i took it out but i did not get a chance to drive it. Can there be something wrong electrically that would cause this??
I did not replace any of the electronics, i did check them all with my meter acording to the manual and they seam fine.
Keith
Old 05-30-2008, 06:56 PM
more info
I just hooked a pressure gage up. I do not have the tech one tool to increase the amps to the pressure control solenoid. so this is all static line pressure in all the gears.
All the gears have 80 lbs of line pressure, reverse will drop to about 40 lbs for a second when you engage it but go right back up to 80.
Not sure that this means any thing with the tech 1 tool not hooked up??
Keith
Old 05-30-2008, 07:36 PM
4l60e
Keith, this sounds like a mechanical problem, like an input sprag, this is not an electronic problem, can you be more specific when you say "the trans did something like this before".
Would it not move in the drive or overdrive position, before the rebuild?
Dana
Old 05-30-2008, 07:58 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Ditto on the mechanical problem.. Did you have the forward sprag apart for cleaning and inspection? They will go back together backwards.
Maybe a cut lip seal in the forward clutch piston?
Old 05-30-2008, 08:03 PM
4l60e
C-10, remember, this trans may have been doing this prior to the rebuild.["maybe a cut lip seal in the forward clutch piston"].
Old 05-30-2008, 08:07 PM
C-10's Avatar
Revolution Calling
true, true.
maybe Keith can clarify.
Old 05-30-2008, 08:12 PM
trans
I did not drive the truck so i really can't say what it did before. I might be able to ask the guy tomorrow if he had to put the selector in 2nd to make it move.
Just a question, if it was the foward sprag why would putting the selector in 2nd make the truck move but if i move it to drive it acts just like neutral??
There is zero engagement in od/or d, the truck asct just like the trans is in park or neutral.
I did have the foward sprag apart during the rebuild, and i re-assembled it like the atsg manual shows, but i guess i could have gotten it wrong..
Keith
Old 05-30-2008, 08:18 PM
also
Not sure if this is related, but the air bag and anti-lock lights are on also.
Keith
Old 05-30-2008, 08:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
addittional items are applied in 2 - 1 , so the vehicle moves.
the forward sprag is backwards.
Pressure drop in R.. then back up is probably from the poor design of Gm on the aluminum piston in the reverse input drum. That hole in the piston should be down sized about 1/2 the diameter .
You should see a pressure rise if you push the gas pedal down as the engine runs.
Reverse should be boosted to about 110 -125 psi . It will be higher than the forward gears.
Old 05-30-2008, 10:18 PM
drive at idle 55-65
drive at stall 170-190
reverse at idle 65-80
reverse at stall 300-325
Old 05-31-2008, 05:07 AM
trans
Ok i did try applying more gas and the pressure does rise.
I am putting it up on stands and yanking the trans back out. Not to be stupid but your 100% sure it's the foward sprag installed backwards???
Keith
Old 05-31-2008, 08:11 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Keith
I'll tell you this;
the vehicle does not move forward in "OD" or "D" .. this usually indicates a forward clutch pack problem or sprag backwards.
When the shifter is in "OD" or "D" , then moved to 2 or 1... the oil is still routed to the forward clutch pack. There are no solenoids applied or released.
IF the forward sprag is not backwards , you have a problem in the forward clutch pack because the power HAS to be transmitted through the forward clutch to move the vehicle.
So.. lets recap;
The vehicle moves forward in 1 & 2 shifter positions per your post. This tells me the forward clutch is operating. The pressure does not seriously drop when the trans is shifted to "OD or "D" , so I am guessing the seals are holding pressure
It does not move in "OD or "D" ..... then it does in lower gear shifter position.
this takes me back to the forward sprag installed backwards.
In my opinion the trans still has to come apart for a repair
Old 05-31-2008, 09:23 AM
trans
Thanks, it's on it way out...should be on the stand by lunch, unless a customer stops and hold me up L.O.L.
Keith
Old 05-31-2008, 11:04 AM
up-date
Got it out, and apart,,,, the foward sprag is on backwards.... I need to fire the guy that did that...wait it was me,,,I am still going to fire me!!!
Crosley, i guess i should install those cup plugs that come in the SK-4l60E kit while i haved it apart (in the reverse piston)
Is it ok to use the scarf cut seals on the stator spport, or do i need to install the tefflon seals and size them??
Keith
Old 05-31-2008, 01:50 PM
C-10's Avatar
Revolution Calling
For me,..I always use the white teflon ones. If you have the tool, it's a snap. Also I use the 4 white uncut seals on the input shaft too.
4L60E Weak Reverse rsruss800 Transmission - Rearend 3 03-23-2008 06:00 PM
4l60e issues Screemincheetawheely Transmission - Rearend 1 03-06-2007 09:49 PM
Lowering - Camber issues 49lincoln Suspension - Brakes - Steering 1 05-25-2006 01:24 AM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 08:47 PM
4L60E issues - advice- maybe Crossley? Tim240Z Transmission - Rearend 0 11-19-2005 10:29 PM
