4l60E L/R clutch clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2010, 09:06 PM
Like to find out what the minimum L/R clutch clearance as measured with dry clutches during mockup. GM specifies a stack height but no clearance.
Thanks
Old 01-08-2011, 10:33 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
.050 to .070 works well. Closer to .050 the beter with 5 frictions in there
Put the snapo ring in and check it that way. Some times there is additional clearance between the snap ring and center support. That can create additonal un-needed clearance
9 inch rear carrier clutch clearance? studebaker transtar Transmission - Rearend 2 04-09-2010 10:39 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
Low/Rev Clutch clearance impa65 Transmission - Rearend 2 06-15-2007 08:09 AM
56 chevy clutch linkage clearance jackfrost51 Transmission - Rearend 2 04-25-2005 10:52 AM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 05:34 PM
