4L60E Limp Mode
1996 GMC Jimmy, 4.3L, 4X4, picked it up for 75 bucks, kid says the trans is bad, but it shifts fine after sitting for a couple of days, after a few miles goes into limp mode, IE: starts in third can manually shift to second, no 4th or TCC lockup, CE light is on. I have heard this can be a simple fix so any ideas would help me out greatly as at this point I need this vehicle badly.
Check engine lite on in the dash? have you checked the fuses for bad ones? Check for corrosion on the fuses too, perhaps use a volt - ohm meter
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Check engine
Yes the dash light is only lit when the trans goes into limp mode, when its shifting fine at first it is off. Will check the fuses, I assume I am looking for standard 12 volts?
you need to scan for codes if the dash 'check engine' lite is coming on...
Guess I got to take a trip to AutoZone then...no scanner out here. I hate to drive it though if its a bad problem, may end up worse than I started.
| T-400 to 4L60E swap - yoke & drive shaft? | y5e06 | Transmission - Rearend | 6 | 11-03-2009 06:47 PM |
| 4L60E problems | pjposton | Transmission - Rearend | 7 | 08-17-2009 06:04 PM |
| 2004 4L60E; Questions. School me! | 04SilveradoMykk | Transmission - Rearend | 3 | 11-26-2008 08:27 AM |
| 4l60e Trans. | GMCTRUCKS | Transmission - Rearend | 11 | 10-21-2007 01:39 PM |
| 4L80E diesel computer | 5foot2 | Transmission - Rearend | 2 | 04-09-2005 12:48 PM |
