4l60e locked up reverse. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2009, 12:50 PM
If I put the reverse sprag in backward would it lock it up in low and reverse. 2,3and drive all will allow the vehicle to move. It lock up in reverse and low. With the engine off you can push the truck forward but not backwards. I think I put the sprag in backwards.
Old 11-18-2009, 01:47 PM
Rexnfx's Avatar
Check valvebody bolts. There are 3 about 8mm longer, and have 8mm socket heads. If you get one in the center a VB, you maybe have hit the sun shell and locked it down. They go toward the rear of VB.
Old 11-18-2009, 09:51 PM
Thank you
I will check that and post what I found.
Old 11-19-2009, 11:05 AM
That was it
Thank you again. I pulled the pan and sure enough that bolt with the 8mm head was right in the middle. When I put it together I put them in finger tight to make sure they did not bottom out. I never felt it hit the shell. I torqued them and it locked the shell up. I moved it with the one that was a tiny bit shorter and a 10mm head.
Old 11-19-2009, 01:41 PM
Rexnfx's Avatar
Glad you got it fixed.
1997 Suburban 4x4, 4l60e no reverse, imagine that. t00lmanii Transmission - Rearend 16 11-02-2009 07:48 AM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
4l60E Slow Reverse jadejoky28 Transmission - Rearend 4 05-21-2009 10:41 AM
4L60E Weak Reverse rsruss800 Transmission - Rearend 3 03-23-2008 05:00 PM
