-   -   4L60e Low Reverse Clutch (http://www.hotrodders.com/forum/4l60e-low-reverse-clutch-224896.html)
abbazabba 10-10-2012 08:04 PM
3 Attachment(s)
98 k1500 4x4 350 with 4l60e
Rebuilding using monster transmissions ss kit for the 4l60e
4L60e Low Reverse Clutch Seems to be to tight when I turn to clockwise it does turn but I would think that it would be more smooth. It does not turn counter-clockwise.. which i do know is correct. Can anyone tell me if this is okay or what needs to be done to troubleshoot?
abbazabba 10-11-2012 05:30 PM
Anybody anybody?
Any thoughts on this? I'm kind of stuck in limbo here since I can't continue my build.. any thoughts on this would be appreciated! Thanks
Crosley 10-11-2012 06:18 PM
new roller clutches are tight usually. Some tighter than others.
I check them bent springs and such and run em
abbazabba 10-11-2012 06:35 PM
Crosley,
Are you saying that it should not be a problem? It should become more free spinning as it is run in the transmission?
abbazabba 10-12-2012 01:44 PM
I called monster trans and talked to there tech department. The guy says that this borg warner sprag is usually pretty tight and even the occasional squeaking noise I am hearing can be normal.
Does anyone object to this information??
motosyco 10-13-2012 09:55 AM
run it and go just make sure you use cushion spring when you reinstall that sprag or you will take out the case
abbazabba 10-13-2012 10:14 AM
Cushion spring on the sprag?
I have a sprag that installs into the low roller assm. with a snap ring on both sides. Could that spring be part of my new sprag?
motosyco 10-13-2012 10:36 AM
I guess I should have been more specific your rear roller is a sprag and where it indexes in the case there is a cushion spring that goes in the case first before your rear roller its kinda bent like a mishaped u
abbazabba 10-13-2012 10:38 AM
Oh yes yes! Yes sir that is installed correctly.
You scared me! I thought i forgot something.. already have the pump on.
Thanks for your help! (on the other thread too)
