4L60e Low Reverse Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2012, 08:04 PM
98 k1500 4x4 350 with 4l60e
Rebuilding using monster transmissions ss kit for the 4l60e
4L60e Low Reverse Clutch Seems to be to tight when I turn to clockwise it does turn but I would think that it would be more smooth. It does not turn counter-clockwise.. which i do know is correct. Can anyone tell me if this is okay or what needs to be done to troubleshoot?
ID:	68361   Click image for larger version
ID:	68362   Click image for larger version
Old 10-11-2012, 05:30 PM
Anybody anybody?
Any thoughts on this? I'm kind of stuck in limbo here since I can't continue my build.. any thoughts on this would be appreciated! Thanks
Old 10-11-2012, 06:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
new roller clutches are tight usually. Some tighter than others.
I check them bent springs and such and run em
The Following User Says Thank You to Crosley For This Useful Post:
abbazabba (10-12-2012)
Old 10-11-2012, 06:35 PM
Crosley,
Are you saying that it should not be a problem? It should become more free spinning as it is run in the transmission?
Old 10-12-2012, 01:44 PM
I called monster trans and talked to there tech department. The guy says that this borg warner sprag is usually pretty tight and even the occasional squeaking noise I am hearing can be normal.
Does anyone object to this information??
Old 10-13-2012, 09:55 AM
run it and go just make sure you use cushion spring when you reinstall that sprag or you will take out the case
The Following User Says Thank You to motosyco For This Useful Post:
abbazabba (10-13-2012)
Old 10-13-2012, 10:14 AM
Cushion spring on the sprag?
I have a sprag that installs into the low roller assm. with a snap ring on both sides. Could that spring be part of my new sprag?
Old 10-13-2012, 10:36 AM
I guess I should have been more specific your rear roller is a sprag and where it indexes in the case there is a cushion spring that goes in the case first before your rear roller its kinda bent like a mishaped u
Old 10-13-2012, 10:38 AM
Oh yes yes! Yes sir that is installed correctly.
You scared me! I thought i forgot something.. already have the pump on.
Thanks for your help! (on the other thread too)
4l60e, chevy, clutch, low reverse, transmission
Which way does the low reverse roller clutch assembly go? old yukon Transmission - Rearend 6 04-22-2011 05:55 AM
4L60e low-reverse clutch retaining clip stuck! old yukon Transmission - Rearend 5 01-25-2011 10:39 AM
4L60E No Reverse/Low Rescue35 Transmission - Rearend 3 09-03-2010 09:13 AM
4L60E low Reverse Stackup 123pugsy Transmission - Rearend 6 04-09-2008 05:09 PM
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 08:31 AM
