Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60e low-reverse clutch retaining clip stuck!
Old 01-25-2011, 05:12 AM
old yukon's Avatar
old yukon old yukon is offline
thanks tnsmith 10
i will give it go.
You said: "that is called the reverse anti-rattle spring" not "lo-reverse clutch retaining clip " thanks for correcting me here.
There are so many different name for it out their. even ATSG call it something different, (see attachment)
Even the directions from the ATSG manual for disassembly seem open to interpretation. eg."remove the lower reverse roller clutch assembly from the case".... which direction?)
thanks again tnsmith 10 .
Name:	lo reserves clutch retaining clip ATSG.jpg
