its going to be stuck, you gota use the output shaft to knock the center support out and that will free it up. lay the trans down on its back and take a heavy soft blow hammer to the output shaft and hit the output shaft from the bottom of the case. as long as the snap ring has been removed, and the inner lugs of the case arent messed up, it should come right out. you will never get the anti-rattle spring out without removing the center support, without ruining the spring. |
thanks tnsmith 10
i will give it go. You said: "that is called the reverse anti-rattle spring" not "lo-reverse clutch retaining clip " thanks for correcting me here. There are so many different name for it out their. even ATSG call it something different, (see attachment) Even the directions from the ATSG manual for disassembly seem open to interpretation. eg."remove the lower reverse roller clutch assembly from the case".... which direction?) thanks again tnsmith 10 . |
Done! Ahha, its the outer snap ring your were refering to.
I just put the rear shaft back in and it all came out, no need to even use a hammer. Thanks tnsmith 10 for the advice. ( thumbs up!) |
| Muncie stuck in reverse? | Mets63 | Transmission - Rearend | 4 | 06-22-2009 07:20 PM |
| 700R4 stuck in reverse | famous 4130 | Transmission - Rearend | 5 | 11-28-2008 10:17 AM |
| 55 stuck in reverse-any ideas | Slickriffs | Transmission - Rearend | 3 | 05-27-2007 03:16 PM |
| Lakewood Clutch fork clip broke/angle of clutch fork | 70bird | Transmission - Rearend | 3 | 04-23-2004 07:04 PM |
| TH350 rear clutch retaining spring | AMDAP | Transmission - Rearend | 10 | 02-29-2004 09:00 PM |
