4L60E low Reverse Stackup
I'm putting together a 94 4l60e and my "guide" mentions that the low/reverse stackup should measure 1.230". Even if I use the thickest selective plate, I won't get that close. It appears if I did follow spec that the retaining ring might not go in as the stack would be too high.Everything that came out seems to be in good shape with zero wear.
Thoughts? Thanks,Pugsy |
I am not sure I follow you.... the old frictions / steel plates were OK, for clutch pack clearance? New frictions and steel plates are too thick / high? There are two frictions that will fit.... t-350 / powerglide and the 700/4L60 design. 700 frictions are about .090 thick. t-350 frictions are about .100 thick not sure if that helps or not. I stack up reverse frictions and steels in the case on the piston.. set the center support in , check clutch pack clearance visually. I've done it that way for many years.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks. So all these facts and figures don't need to be followed exactly as long as there is sufficient clearance.
On my 3-4 clutch pack, I have .054" clearance. The "guide" calls for .060"-.083". Is the .054" sufficient? Would a visual apply here as well? What would happen if its too tight or too loose? Thanks, Pugsy. |
Facts and specs are important. I simply use a visual inspection as I build since I have done this tranny thing for decades. .054 will work on a 3-4 clutch pack 700r4 IF you have a daily driver , low RPM application. If you are going to shift at higher RPM (above 4500) the clearance needs to be opened to .070 IMHO. The 3-4 clutch pack can tend to apply centrifugally at higher RPMs. I often install stiffer springs in the aluminum drum to help hold off clutch packs at higher RPMs.
Thanks Crosley.
This is for a friend of a friend's mini van. Its just a stock application. I also checked the low reverse pack and found I have about .065" clearance. Pugsy. |
Thanks. I found an instruction sheet in the rebuild kit that spec'd less than the clearance I have, so it should be fine.
| No reverse after Overhaul | SG2nite | Transmission - Rearend | 9 | 10-31-2004 03:52 PM |
| 4l60-e no reverse problem | ragman1 | Transmission - Rearend | 6 | 10-18-2004 04:06 PM |
| th350 reverse double apply??? | eskoskimo | Transmission - Rearend | 1 | 10-11-2004 05:07 AM |
| TH700R4 No reverse! | dope_pm5k | Transmission - Rearend | 6 | 08-26-2004 12:50 AM |
| how low on fluid (TH350) before it quits moving? | HotRodF100 | Transmission - Rearend | 4 | 10-11-2002 06:34 PM |
