4l60e Lower and reverse clutch assembly set up, is their a differenece ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2013, 01:58 PM
Hi All I was just checking my parts on the 4l60e after my band failure, and noticed my tranny only had one snap ring on the lower and reverse clutch assembly.
Is there more then one type of set up , a GM picture I found has 2 snap wring , mine only has one.
Is one snap ring a problem ??
Hope'n someone who understands the 4l60e can help out .
V8Truck
Name:	4L60e lower and reverse clutch assembly.png
Old 09-06-2013, 09:45 PM
Yes it is needed.
Found it the other day at the wrechers.
4L60e Low Reverse Clutch abbazabba Transmission - Rearend 8 10-13-2012 11:38 AM
Which way does the low reverse roller clutch assembly go? old yukon Transmission - Rearend 6 04-22-2011 06:55 AM
Lower reverse clutch race and new sunshell, is a mod needed old yukon Transmission - Rearend 8 04-11-2011 08:21 PM
4L60e low-reverse clutch retaining clip stuck! old yukon Transmission - Rearend 5 01-25-2011 11:39 AM
what clutch assembly jafroyd Transmission - Rearend 6 09-16-2009 10:43 AM
