Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E Manual Upshifts Only Hot
Old 05-31-2011, 10:34 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by 123pugsy
Thanks.
Only after its warmed up?
with what your explaining to me its like its not down shifting back to low after you come to a stop, correct?
if you have any scan tool with a live data stream, you can watch the shift solenoids.
also you can watch the trans temp as well to see if it shows any problems. ( the trans temp sensor is in the pressure manifold.)
it will also show whether or not the computer is commanding a down shift back to low gear.
there are times that a electronic device can test good and work for a certain length of time, say like a car warming up to operating temp and quit working once the vehicle has gotten hot.
