-   -   4L60E Manual Upshifts Only Hot (http://www.hotrodders.com/forum/4l60e-manual-upshifts-only-hot-199555.html)
123pugsy 05-31-2011 03:11 PM
I have a problem with a friend's tranny. I helped him out with it.
Fresh rebuild (1995 TransAm) with all new clutches, steels, bonded pistons.
It had a Transgo shift kit already and everything put back as per Transgo instruction sheets.
After a drive around the block and stopping at the lights, it won't automatically upshift anymore.
It will upshift fine manually.
Thoughts?
tnsmith10 05-31-2011 04:27 PM
Thoughts?
either shift solenoids, or the pressure manifold switch.
123pugsy 05-31-2011 05:01 PM
Thanks.
Only after its warmed up?
tnsmith10 05-31-2011 09:34 PM
Thanks.
with what your explaining to me its like its not down shifting back to low after you come to a stop, correct?
if you have any scan tool with a live data stream, you can watch the shift solenoids.
also you can watch the trans temp as well to see if it shows any problems. ( the trans temp sensor is in the pressure manifold.)
it will also show whether or not the computer is commanding a down shift back to low gear.
there are times that a electronic device can test good and work for a certain length of time, say like a car warming up to operating temp and quit working once the vehicle has gotten hot.
123pugsy 06-01-2011 03:44 AM
Thanks tnsmith.
