4L60E Manual Upshifts Only Hot - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 03:11 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I have a problem with a friend's tranny. I helped him out with it.
Fresh rebuild (1995 TransAm) with all new clutches, steels, bonded pistons.
It had a Transgo shift kit already and everything put back as per Transgo instruction sheets.
After a drive around the block and stopping at the lights, it won't automatically upshift anymore.
It will upshift fine manually.
Thoughts?
Old 05-31-2011, 04:27 PM
tnsmith10's Avatar
when will it rain???
Thoughts?
either shift solenoids, or the pressure manifold switch.
Old 05-31-2011, 05:01 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks.
Only after its warmed up?
Old 05-31-2011, 09:34 PM
tnsmith10's Avatar
Thanks.
with what your explaining to me its like its not down shifting back to low after you come to a stop, correct?
if you have any scan tool with a live data stream, you can watch the shift solenoids.
also you can watch the trans temp as well to see if it shows any problems. ( the trans temp sensor is in the pressure manifold.)
it will also show whether or not the computer is commanding a down shift back to low gear.
there are times that a electronic device can test good and work for a certain length of time, say like a car warming up to operating temp and quit working once the vehicle has gotten hot.
Old 06-01-2011, 03:44 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks tnsmith.
4l60e full manual reverse valve body 53belair Transmission - Rearend 1 02-24-2010 10:43 AM
T-400 transmission, no upshifts nathanblok Transmission - Rearend 3 09-28-2009 04:42 PM
4L60E online manual or guide... Augusto Transmission - Rearend 3 07-19-2007 10:17 PM
fully manual, electrically shifted 4L60E ? Augusto Transmission - Rearend 15 05-22-2007 02:43 AM
T400-want to allow manual upshifts stepside454 Transmission - Rearend 2 09-01-2004 03:13 PM
