4L60e MLPS question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 04:56 AM
4L60e MLPS question
what is the box that is around the shifting arm? and how do you adjust? and does it have something to do with the throttle position sensor? I was told to move it until it starts in neutral which I did now it seems to run worse kind of dies out around 1500 rpm. Thanks
Old 10-20-2011, 09:18 PM
Crosley's Avatar
Wiki Edits: 1659
I think you are talking about the Manual Lever Position Sensor at the linkage arm on the trans.
That provides information to the PCM as to which gear is selected by the shifter.
It should not cause a problem at 1500 RPM
4L60E Question HipCATZ Transmission - Rearend 3 07-24-2011 04:30 PM
4l60e question chevrolet327 Transmission - Rearend 2 02-03-2011 10:09 AM
4l60E EPC Question JSGAuto Transmission - Rearend 3 01-30-2009 05:45 PM
4L60E question Vortech 4.3 Transmission - Rearend 9 04-15-2008 08:29 PM
4L60E question 36scsc Transmission - Rearend 12 01-16-2005 08:05 AM
