4L60E No 3rd or 4th - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2007, 03:35 PM
4L60E No 3rd or 4th
I just bought a rebuilt transmission for my 2000 chevy silverado 1500 5.3 2wd i jus recently put the transmission on but it will not shift into 3rd jus 1-2 an thats it reverse works fine any suggestions
Old 12-27-2007, 05:24 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what does the builder you bought the trans from say about this problem?
Unplug the connector at the trans case.. that should put the trans into default mode which is 3rd gear. Test drive for third gear function.
700R4 3rd & 4th lockup chrisape Transmission - Rearend 6 11-14-2006 06:25 AM
4l60E 4TH problem Stanley H Transmission - Rearend 1 04-28-2005 06:48 PM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 12:34 PM
T-56 NO MORE 4TH GEAR, and NO 3RD GEAR SYNCOS!!! chevyelc81 Transmission - Rearend 5 12-05-2004 10:39 AM
1st, 2nd, 3rd! No 4th gear Deadtemple Transmission - Rearend 6 10-15-2003 08:15 PM
