4l60e No 3rd Or 4th - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2011, 02:39 PM
4l60e No 3rd Or 4th
I have been searching the forums for any info on my trans, no 3rd or 4th. I was a Chrysler trans tech for about 8 years, until a back injury. Was hoping to find a "non-invasive" solution. Any suggestions would be helpful. Thanks
Old 09-01-2011, 08:02 PM
Thanks
I have been debating doing this myself, with a little help from my son. I think I am going to try it, so I will probably be asking many questions of all the knowledgeable people on this forum. Thank you in advance.
Old 09-02-2011, 08:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Year , make , mileage on the unit?
You say no 3rd or 4th gears... does the trans stay in 2nd gear and no further upshifts , or does it seem to go into a neutral and the engine revs up?
Old 09-03-2011, 08:54 AM
no 3rd or 4th
1997 blazer 4.3L does not feel like it is upshifting. Press on pedal harder, will go faster, can go 45+ let off gas it coasts, step on gas harder will pull.
Thanks
Old 09-03-2011, 11:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
as mentioned, any 'check engine' lite on?
Shift solenoids can fail in 2 methods. Electrical failure will set a DTC ( trouble code)... if they fail hydraulically, no code usually is set and the CEL is not activated.
A quality scanner that can read a live data stream to see if the PCM is commanding the shift to 3rd gear would help.
Or you could simply unplug the trans connector at the case and see if the trans is in 3rd gear or 2nd gear.
Pulling the fuse for the trans operation would function like unplug of the connector
Old 09-03-2011, 11:55 AM
4l60e
I did unplug trans connector and drove, did move, but don't know if it was 2nd or 3rd. Had to press hard on gas, so I think it was 3rd. I have replaced 1-2, and 2-3 solenoids, no difference. Pan had dark "film" , no chunks or silver pieces . Fluid was dark, and smelled bad. I bought it used, and have not had it on the road. Does not feel like it is trying to shift up to 3rd.
Again thanks.
Old 09-04-2011, 06:27 PM
3-4 cclutch failure
Thaks, I needed that. LOL
Old 09-09-2011, 10:41 PM
B@D B@D is offline
Transmission specialist 26 yrs
It could have a bad 3-2 downshift sol which is in front of valvebody which would stop it from upshifting but would not make it slip if it slips or engine revs when time for 3rd the 3-4 clutches are bad .
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
4l60e no first 84'Monte Transmission - Rearend 5 10-10-2009 10:37 PM
4l60e Einarg Transmission - Rearend 1 12-04-2008 03:13 AM
4l60e Dannyv2221 Introduce Yourself 2 10-25-2007 06:01 PM
What is the '60' in 4L60E 36scsc Transmission - Rearend 1 10-26-2004 01:41 PM
