4L60E no first gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 07:06 PM
4L60E no first gear
I have a 1995 Jimmy 4.3 w/ 4L60E transmission. It had been sitting for about 4 months and it has 15000. miles on it. I went to drive it and it did not start out in 1st gear it seems to be starting out in 2nd gear or higher. I hooked up my snap on scanner and drove it around. I have to put the shifter in 2nd are 1st to start off if I leave it in drive it doesnt seem to move very well and I'm afraid to burn up something. I can see on the scanner what gear the trans is in and when I put it in drive after about 20 mph everything seems to work OK, It down shift and up shifts but when I come to a stop the ecm tells the trans to shift to first but it does not.
ANY IDES
Old 01-14-2008, 12:55 AM
chevyluv77's Avatar
Yea! Just Yank it Out!
First thing i would check is the Speed Sensor.
I had the same problem on my GMC.
Get a voltmeter test that baby out.
Old 01-14-2008, 06:52 AM
I have to replace the shifting cable first then Im going to plug the scanner back in and see if it registers any speed from the sensor. I all so read that there may be a shifting solenoid problem, solenoid A may not be working properly.
Old 01-14-2008, 05:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
depending on Snap-on the scanner you have, you can manually shift the trans with the scanner. This would test each gear range.
Shift Solenoid can be electrically OK , yet not function hydraulically... this will cause shift problems , yet NOT set any codes
Old 01-15-2008, 07:03 AM
I replaced both shifting solenoids in the transmission. Test drove the Transmission and it has 1st gear again and it shift good too.
Thanks for everyone input, this forums is great for troubleshooting problems
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
delay going from 2nd to 3rd gear aafc Transmission - Rearend 3 12-17-2007 07:54 PM
4L60E won't start in 1st gear... Augusto Transmission - Rearend 1 06-01-2006 02:09 PM
