4L60E no OD??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2009, 10:22 PM
HELP!!! 4L60E no OD???
I put a new (rebuilt) tranny in my 97 chevy K1500 recently and buggered up the VSS during the install (I had old tranny out a couple of times previously). Had to put shift lever in neutral to start and the indicator needle slipped (lagged behind what gear I actually had selected). Other than that, the tranny worked as it should, though I did have a check engine light. After a couple of weeks driving it this way (I know, but saying I didn't have time would be an understatement) I lost 4th gear. Finally put in a new switch today, rigged per the manual and everything works perfectly now except I didn't get 4th back. I dumped the codes when I changed the switch and remember seeing an 81 (2-3 solenoid I believe) but nothing has popped up again since changing the switch. I've only put about 10 miles on it so maybe it will come back.
Anyone got a good idea what happened? Could I have burned up one of the solenoids by driving with the bad switch? Does the 2-3 solenoid have control over OD? Thanks for any help.
4l60e Trans. GMCTRUCKS Transmission - Rearend 11 10-21-2007 01:39 PM
4L60E whining in 2nd 3rd and OD but not 1st vtf_thor Transmission - Rearend 1 08-17-2007 09:15 PM
4L60E turns to slush in od desotot Transmission - Rearend 2 07-22-2007 11:05 PM
98 astro 4l60e what swaps out? 3rdgenLT1 Transmission - Rearend 4 06-06-2007 09:16 AM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
