4l60e no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2013, 05:22 PM
4l60e no reverse
I got a 96 sonoma 4.3l vortec and it has no reverse. I have rebuilt a 91 700R4 but i dont think the 4l60e needs rebuilt. The truck pulls great in every gear buy reverse nothing rpms go high nothing. I know alot of 4l60e have bad sun shells that makes it go into reverse.
I want to know if i pull the trans and drop the pan if the fluid is red and clean can i just replae the sun shell. Is their any way to tell befor i get the trans out if their is anything wrong besides the sun shell.
Old 03-31-2013, 06:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the drive shell breaks... the trans will not have 2nd gear, 4th gear or reverse
Old 03-31-2013, 06:43 PM
OK thin whats wrong i have every gear 1st 2nd D and OD are strong no slip nothing wrong just no reverse.
Old 03-31-2013, 10:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You should have a problem with the low-reverse clutch and / or the reverse input clutch pack. Those work together to create reverse if all else is OK.
What amount of mileage is on the transmission (if you know) ?
Any recent service work on the transmission?
Old 04-01-2013, 07:29 AM
235k dont know if trans was ever servised but non of the other gear give any problems.
4L60E Reverse Only maycko Transmission - Rearend 5 08-15-2011 02:33 PM
4l60e No Reverse cody_edge_1991 Transmission - Rearend 14 07-31-2010 07:23 PM
4l60e...no reverse probie302 Transmission - Rearend 1 10-05-2009 09:56 PM
4l60e no reverse or first 4.8t Transmission - Rearend 6 05-12-2008 06:22 PM
4L60E No Reverse LAFD Wrench Transmission - Rearend 10 01-26-2008 02:08 PM
