Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E no shift, one gear only
Old 05-26-2011, 09:08 PM
nine4gmc's Avatar
nine4gmc nine4gmc is offline
ok, i removed the 4.3l engine, 4l60e transmission, engine harness and ECM from the 94 gmc and installed a 5.7l from a running vehicle along with its harness and ECM. i found an exact replacement 4l60e in the salvage yard, they both even have goodwrench remanufactured stickers on them.
the truck is running smooth but this transmission does the exact same thing. only first and reverse, no shifting. i can put it in OD and take off, engine revs up to redline and im traveling about 15-20 mph? i let off the gas and it the rpms drop low but im still coasting fast, instead of slowing down relative to the rpms.
i can goose it while coasting and it will take off again but high rpms and no shift.
it does the same thing in 1,2,3 as it does in OD. low and reverse work seemingly fine.
any home diagnosis i can do, its apparently a common issue with these goodwrench trans...
