Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60E noises
Thread: 4l60E noises
Old 08-26-2012, 02:23 PM
Low82C10 Low82C10 is offline
4l60E noises
i have a 82 chevy short bed c10, im doing a 5.3/4l60e swap. just a few things to finish up, today i hooked up my drive shaft and popped it into N and pushed it out of the garage and i noticed when it moves forward, it makes a whining noise, kinda like the noise when your tire is on a smooth surface and you turn the wheel. i did not know where it was coming from so i put the rear end on jack stands and i took the drive shaft off the diff and spun it freely and it only makes the noise when i spin it counter clock wise. i know i dont have fluid it in due to changing the fluid and filter. but i just dont know if this is normal or is something wrong?
