Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60E noises
Thread: 4l60E noises
Old 08-26-2012, 09:20 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by Low82C10 View Post
so this is normal even if it does it in every gear except for park?
You do know the automatic trans operates on hydraulic pressure?
if the engine is not running , the trans is in the same gear all the time when not in park.
I am thinking you do mean the engine is not running?
