4L60E non-interchange issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2009, 02:23 PM
fast68's Avatar
likes chevy trucks & boobies
ok we have gotten another c1500 truck in that needs another 4L60E trans put in it. the last one was a 97 and we could not find one in a yard anywhere because no yard had one for that specific year
they said that it had to be from that specific year only.
so we had to take it to a shop and have it rebuilt.,
now we have a '98 right now that lost reverse and we are stuck with the same problem as with the 97.
how and why do these only fit one single year and wont interchange with any others ?
with what year did this crap begin ?
must have been about 94 or 95 ?
thanks
Old 05-21-2009, 04:08 PM
now we have a '98 right now that lot reverse and we are stuck with the same problem as with the 97.
thanks
I've been getting this BS with 4L80E transmissions. The problem is that the interchange guides are exact interchange only, whereas the differences are often minor. For example, during that period GM changed out the cooler line fittings from flare fittings to the quick connect. You can change the fittings in the block. Same thing with the neutral safety switch. Some are on the column and some are on the exterior of the trans. Turns out you can sometimes change the shifter shaft in the trans to go one way or the other. If you need the switch on the trans, you need to ensure that the case has the mounting holes for it, however.
The biggest problem is the electrical interface. There are some internal differences in wiring and in function. These you need to understand if you are not doing an exact year and application swap.
Old 05-21-2009, 07:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
on the 4L60e ... 1995 - 96 - 97 -98 will interchange with the PWM lock up strategy . SOme 1998 have a removable (unbolts) bell housing. that will not interchange easily with the earlier designs.
what must be watched on a 1997 unit is the 3-2 solenoid. The ohm rating was changed from 1996.
the 1997 solenoid 3-2 will be a white plastic. earlier solenoids have a metal stem or a gray - black plastic.
also.... watch for shifter bracket - cable mounting stubs... some cases have extra stubs , others do not
Old 05-21-2009, 07:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as you know you need the spubs for the MLPS to bolt on.... also watch for the stubs for the shifter cable mount.
Old 05-21-2009, 07:32 PM
fast68's Avatar
hmm so technically you could just swap these parts and be ok with using another year right ?
altohugh that being said i dont know my internal trans parts very well for the most part and wouldnt know which parts are these and specifially where they are located, hmm
but regardless it sounds like minor changes..
interesting..
i got lucky on this 98 however, as it turned out to actually be a K1500 and i happened to locate 4 of these trannies in yards near here for this year make model for 350 bucks each,
so i got off easy this time,
unlike with the 97 C1500.
we plan on pulling that truck in the shop real to pull the bad trans out. and pick up a good trans tomorrow.
thanks!
Old 05-27-2009, 05:42 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I've got a 98 4l60e and a guy wants to put it into a 96.
Can I just change the 3-2 solenoid from his into the one I have?
Old 05-27-2009, 08:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the connectors are different design to avoid a mistake.... I guess you can hack up the connector to make it fit?
Old 05-28-2009, 04:46 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks.
That's the only difference I could find betwwen the 2 units in the update handbook.
Pugsy
Old 05-28-2009, 03:33 PM
fast68's Avatar
well the replacement trans is in the truck now.
im curious as to why you cannot unplug the range slector switch assembly harness plug. the gray colored connector specifially.
it just will not slide out of the connector part of the switch assembly housing no mater what you try to do.
what is the deal with this ? is there some kind of lock release on it somehow ??
i figured that maybe it was stuck together with that tar stuff like with fuel pump relay plugs commonly i have found over the years,
also same stuff as they use on the relay plugs for the firebird and fiero headlight motors. black gooey tar crap.
but nope i dont see nay of this stuff on this plug. its worse than that.. like its been locked or pinned on.
thanks again!
Old 05-28-2009, 07:37 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The ATSG service manual mentions this problem.
It states that high heat may cause the sealing compound in the switch to melt and flow into the connectors, sealing the connectors to the switch.
They say to let it hang when changing the tranny unless there are electrical problems with it to deal with.
Old 05-28-2009, 07:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
use heat on the connector... some folks use a lighter or a heat gun.
must be careful to heat slowly and pull at same time.
95 K15 4L60e issues indianamudslinger Transmission - Rearend 3 02-05-2009 07:24 PM
4l60e issues Screemincheetawheely Transmission - Rearend 1 03-06-2007 09:49 PM
4L60E interchange Ohio-Dan Transmission - Rearend 1 02-23-2007 06:10 PM
4L60E issues - advice- maybe Crossley? Tim240Z Transmission - Rearend 0 11-19-2005 10:29 PM
4L60E interchange question Jessie Transmission - Rearend 5 01-05-2005 06:35 PM
