4L60E, Odd Problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 11:27 PM
FastOrange's Avatar
4L60E, Odd Problem.
My 4L60E is screwing up, Up-shifts just fine (Manually or if i just leave it in OD or 3rd) But if i downshift while going down a hill, i can feel the transmission engage the gear i put the shifter in, but it wont hold me back, it acts like its in neutral until you give it gas.
If i leave the transmission in OD and stop at a light and stomp on it, it will still lay rubber, or if i downshift to 1st and stop it will also lay rubber.
ATF is Fresh, just had a flush last Monday, It still looks new, no burning smell, and is all topped up.
Any ideas guys?
Also should add that im using a Holley TPS kit on my 670 Carb, So no more tbi, have been running this same setup for the last 2 months with NO problems.
Old 10-27-2010, 05:33 PM
Rexnfx's Avatar
No engine braking or no hold back
Is possible, do to no coast clutch operation. There is only two very small friction disks to supply engine braking, they don't take abuse well.
Old 10-27-2010, 08:08 PM
SSedan64's Avatar
So no Engine braking?
Overrun clutches bad as Rexnfx said^^^.
Old 10-27-2010, 08:16 PM
FastOrange's Avatar
So solution is to get a basic rebuild kit and replace all the clutches?
Old 10-28-2010, 09:01 AM
Rexnfx's Avatar
Don't know why I said coast clutch? But ya, overrun clutches...
A basic rebuild kit may do the job. BUt there are plenty of other things that wear also, good luck
Old 10-28-2010, 12:28 PM
FastOrange's Avatar
Maybe i should just swap it out with the TH400 i have, even have a high stall for it.
Its one thing after another in this truck.
4l60E lock up problem yeepman2 Transmission - Rearend 5 01-31-2011 07:17 PM
odd rear suspension problem william27103 Suspension - Brakes - Steering 1 10-18-2004 03:53 PM
ODD Timing Problem 71gtx Engine 9 10-20-2003 10:01 PM
odd timing problem 71gtx Electrical 3 10-20-2003 12:48 PM
Odd 4.3 problem V8 S-10 Engine 5 07-08-2003 05:21 PM
