-   -   4l60e output shaft seal? (http://www.hotrodders.com/forum/4l60e-output-shaft-seal-224937.html)
abbazabba 10-12-2012 03:29 PM
1 Attachment(s)
I need help finding the right seal for my output shaft? What type of seal is it? Standard Color? See the picture. thanks
Crosley 10-12-2012 09:26 PM
no idea what you are talking about.
no seal is located where the finger is pointing
abbazabba 10-13-2012 08:27 AM
There is a grove machined into the shaft at that location that looks like it would hold an oring or something. My atsg manual does list a "output shaft seal" in that area.
Crosley.. are you saying there is no seal of any sort on the output shaft?
motosyco 10-13-2012 09:48 AM
When that trans was new there used to be a tin cup with an oring in it that was pressed on in that location on the output shaft it used to seal the opening of the yoke to keep it from filling with oil gm stopped using and Ive never seen a rebuilder put it back on
abbazabba 10-13-2012 10:10 AM
Was that on 4x4 models as well. Sorry I don't think i specified that. I saw that tin cup thing on the 2wd model shaft.
motosyco 10-13-2012 10:31 AM
just 2 wheel drives
