4l60e output shaft seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2012, 03:29 PM
I need help finding the right seal for my output shaft? What type of seal is it? Standard Color? See the picture. thanks
Old 10-12-2012, 09:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no idea what you are talking about.
no seal is located where the finger is pointing
Old 10-13-2012, 08:27 AM
There is a grove machined into the shaft at that location that looks like it would hold an oring or something. My atsg manual does list a "output shaft seal" in that area.
Crosley.. are you saying there is no seal of any sort on the output shaft?
Old 10-13-2012, 09:48 AM
When that trans was new there used to be a tin cup with an oring in it that was pressed on in that location on the output shaft it used to seal the opening of the yoke to keep it from filling with oil gm stopped using and Ive never seen a rebuilder put it back on
Old 10-13-2012, 10:10 AM
Was that on 4x4 models as well. Sorry I don't think i specified that. I saw that tin cup thing on the 2wd model shaft.
Old 10-13-2012, 10:31 AM
just 2 wheel drives
Output shaft wobble T Evans Transmission - Rearend 4 05-22-2012 10:38 AM
700r4 output shaft JTGochenour Transmission - Rearend 1 02-08-2012 05:26 PM
output shaft seal for Th-400 Titanium Transmission - Rearend 10 12-18-2010 02:50 AM
TH-350 Output Shaft Seal Help leejoy Transmission - Rearend 2 01-24-2007 08:51 PM
C5 output shaft loose k2mooch Transmission - Rearend 1 03-17-2004 04:50 PM
