4l60e is overhaeting - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2011, 11:40 AM
jtf jtf is offline
Put new Planetary gear on input shaft and new clutches in 4l60e and now the tranny is overheating what could be wrong.
Old 07-26-2011, 02:36 PM
tnsmith10's Avatar
when will it rain???
lets see here, you just replaced a planet and clutches and are wondering why its over heating...
did you rebuild the unit, or did you just replace the broken/bad parts? did you buy a new torque converter? did you flush the cooler lines?
did you reaqlize that when you had it apart that with what you replaced describes an overheating/ lack of lube condition in the first place? can you tell me what you did to cause the problem???
z28 4l60e turbofirebird350 Transmission - Rearend 1 12-18-2010 06:02 PM
4L60e M30 mywidebody02 Transmission - Rearend 3 04-13-2010 10:37 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e ??? Badazz93 Transmission - Rearend 3 03-19-2009 02:47 PM
Noo 4L60E LT1-XJS Transmission - Rearend 8 09-05-2007 06:17 PM
