4L60E P0751 and no reverse ,late 1-2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 05:59 PM
LATECH's Avatar
I have a 4L60E and it has no reverse and the 1-2 is Waaaaay late (hi RPM)
Also accompanied by the P0751 , 1-2 solenoid stuck off/performance (not a circuit problem code)
The 1-2 and 2-3 shift solenoids are on the rear of the valve body but Shopkey doesnt specify which one is which.
Anybody have an Idea what I should look at?
The valve under the solenoid towars the passenger side seemed stuck, so it was pulled and checked...seems to move free now. There was no spring in it
The valve under the solenoid towards the driver side has a spring behind it and seemed to move freely when checked.
Also after these 2 items were checked and filter change and refill, the wheels turn forward when in reverse.
What should I look for?
Fact is stranger than Fiction
Old 04-04-2013, 07:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mileage on the transmission? (if known)
Does 3rd and over drive (4th gear) function?
Late 1-2 shift with a no reverse complaint is usually a 1 - 3 shift and the drive shell is broken. Broke drive shell = no reverse , no 2nd gear, no 4th gear
Reverse in that trans is not created by solenoids. It is controlled via the manual valve moved with shifter,
You probably have a failure in the reverse input clutch of the low-reverse clutch.
The Following User Says Thank You to Crosley For This Useful Post:
LATECH (04-05-2013)
4l60e no reverse mafiacustomz Transmission - Rearend 4 04-01-2013 08:29 AM
4L60E Reverse Only maycko Transmission - Rearend 5 08-15-2011 03:33 PM
4L60E reverse gone wwy6211 Transmission - Rearend 2 07-03-2010 12:26 PM
4l60e no reverse or first 4.8t Transmission - Rearend 6 05-12-2008 07:22 PM
4L60E No Reverse LAFD Wrench Transmission - Rearend 10 01-26-2008 03:08 PM
